I'm trying to use the ultraganttviewcontrol with my database, but i'm not finding the correct way to bind the projects and task datasources. I already tried to bind my database to a ultragrid and that works fine. So my question is if you can point me in the right direction of an example with a database connection and what the best method is to do the databinding. I would prefer using entity framework if that is possible.
Kind regards,
Robbe
Hello Sahaja,
I resolved my null pointer exception. When I added my calenderinfo in the designer (by using the properties) I got the exception. But in your project I never get the null pointer exception. So I don't really know why I can't do it with the designer but it is solved. Thank you for your help.
Hello Robbe,
I have modified the attached sample to demonstrate how you can add a custom Color column to the GanttView and make it as a dropdown using a ComboEditor.
Please clarify the complete 17.1 build number so I can test it with the exact version to see if I can reproduce the null pointer exception that you were mentioning about.
Like I mentioned before, the data modified in Gantt View should be automatically updated in Database. The underlying Database should not matter to observe this behavior.
Sincerely,Sahaja KokkalagaddaAssociate Software Developer
3782.WinGanttViewBindToData1.zip
***BUMP***
Hello Sahaja Kokkalagadda,
I already had found that example but it doesn't work for adding the custom column, I have a null pointer exception (see my added code).
Also when I change the way of populating the dataset in your example to getting it from the database, it still doesn't update my database.
I've added a small example of my code, but you will still need a database. I'm using version 17.1.
ProjectPlanning.zip
The data modified in Gantt View should be automatically updated in Database. Have you tested this behavior in the sample I attached previously?
To add a custom color column, you can refer to our online Gantt View Custom Columns sample.
It is possible to make the custom column as a dropdown by adding a ComboEditor to it. For example, you can write something like this to achieve it:
EditorWithCombo combo = new EditorWithCombo();
ValueList comboBinding = new ValueList(); for (int i = 0; i < 10; i++) comboBinding.ValueListItems.Add("Item " + i.ToString());
this.ganntView1.GridSettings.ColumnSettings[CustomColumn].Editor = combo; this.ganntView1.GridSettings.ColumnSettings[CustomColumn].ValueList = comboBinding;
Please let me know if I may be of further assistance.
