When using column header allowediting with doubleclick or manual it seems to blow away the column names when a columnchooser is diplayed. Any reasonable workarounds?
Hello Nick,
Thank you for the update.
The issue has been fix with the latest version V17.2.20172.2020 , i would recommend you to apply this patch in order to get the fix of the issue:
http://builds.infragistics.com/products/WinForms/2017.2/Infragistics_WinForms_20172.2020_SR.zip
Let me know if you need further assistance.
17.2.20172.2006
Hello Nick ,
Thank you for posting to our forum.
I did some research about Ultrawingrid Column Header with ColumnChooser and found we had one issue with this long time back, which is been fixed now.
So I would like to know which version (and build no) of control you are using ?
Looking forward to hearing you back.
