Hi, I am trying to create a Sales Pipeline Funnel Chart. What I've got are 4 Sales stages. The funnel chart should always be ordered by the order of the stages: Stage 0, Stage 1, Stage 2, Stage 3. What happens is that since stage 3 has more volume than stage 2, the order I get is Stage 0, Stage 1, Stage 3, Stage 2.
I found the SortStyle.Ascending property, but really what I want is to sort by X Axis (Sales Stage) not Y Axis (volume). Is this possible?
Hello Richard,
The XamFunnelChart supports the Bezier Curve. Although with our samples I couldn't get it quite like your setup on the left. I would test our "Use Bezier Curve" sample in our Samples browser.
I gave the new funnel chart a shot and like the new data binding. However, I feel like the display of the chart is a step back. My current funnel chart is 3D and in my opinion, looks much better than the new one:
I couldn't seem to locate much in the way of sample VB code for customizing the appearance of the new funnel chart. Can you point me in the right direction? I would much rather stick with my current chart if I could find a way to sort it by sales stage.
You would need to migrate to our newer UltraFunnelChart. https://ko.infragistics.com/help/winforms/funnelchart-data-binding
I am trying to accomplish the exact same thing as David and am running into the same problem. I cannot figure out how to sort the funnel by the stage number, not the sales amount. I am not able to find the ValueMemberPath property on the chart control. I am using the UltraChart control in version 19.1. Can you give me a more detailed explanation of how to do this? I am using VB.net
OK great! Let me know if you have any questions.
Sincerely,
Michael Di FilippoAssociate Software DeveloperInfragistics, Inc.www.infragistics.com/support
