295
UltraGrid Row Height Windows 10
I am having an issue with an application when the user will dock/undock their laptop while the application is running. The row height will readjust to a height that cuts off the bottom part of each row.
I have tried calling PerformAutoResizing after the form's size has changed, setting the AutoScale to none, Setting each UltraGridRows  RowSizing to RowSiziing.AutoFree.
This only occurs on Windows 10 and it doesn't always occur when the user docks/undocks their laptop. Any ideas on what could be causing the issue with the Grid's row sizing.
  • 12480
    Hi Jason,
    I tested the attached sample on my machine and did not see any unusual behavior. My test environment used three 1920x1080 screens. The laptop screen had its scaling set to 125% and the other two were set to 100%. The laptop screen uses an integrated card while the other two screens use a dedicated GPU. My test steps were simple:
    1) Run the application
    2) Undock the laptop and observe the application's behavior
    3) Dock the laptop and observe the application's behavior
    4) Repeat steps 2 & 3 a few times, since the issue does not occur 100% of the time.
    Please download my sample and test it on your environment to see whether you experience the row height issue.
    RowHeightDockTest.zip
  • 12480
    Hi Jason,
    We use docking stations here, so I will put together a small sample and try this out. I will let you know whether I am able to reproduce this issue on our end.
