715
Need notification when Context Menu Popup window closes.
Is there a way to get notification when a popup menus window is closing?  I have a conflict between tooltips and a context menu right mouse click.  I get both the tooltip and the popup menu.  The tooltip shows up after the delay time expires (1 second in my case).  I set the context menu the following way:
 ultraToolbarsManager.SetContextMenuUltra(this, "MenuName");
 I want to be able to disable tooltips when the right mouse is pressed down and enable tooltips when the the context menu closes. (Or maybe a better way?)
Rich
  • 44743
    You can handle the AfterToolCloseup event and check the SourceControl on the event args. If it is not null, the menu which closed was a context menu for that control.
