75
Need Help with Scatter or Line
Hey, first off I'm sorry for the question if it sounds easy, I'm pretty new with ultrachart and it seems hard to find a lot of documentation on it.
 Either way what I need is a chart that is in column format  The catch is I need 2 groups on the x axis of labels.  So my x axis is going to be comprised of date and there will be months and years, but sometimes there will be 2 years in one chart.  So I need sections on the bottom for each year and then above that the months within that year.  This is in C# btw.
 My data set will be coming in from a sql select like this:
 Year       Month         Information
2008         11               300
2008         12               545
2009         1                 444
2009          2                400
 So I would need year as my main x axis and month as my secondary x axis, with Information as my y axis.
 Any help on this issue would be much appreciated or a link to some good examples or documentation would also help just as much.
Thank you
  • 26458
    So you wanted something like the attached image? Might be a bit tricky with the data you have provided. First of all, the chart can't group multiple rows with the same year into one series, which is typically a single row. Second, each series must have an equal number of points, so you won't be able to display 2 months in one series and 3 months in the other.
    The table for this chart image would look like this:
    DataTable dt = new DataTable();
    dt.Columns.Add(
    "RowLabel", typeof(string));
    dt.Columns.Add(
    "month1", typeof(double));
    dt.Columns.Add(
    "month2", typeof(double));
    dt.Rows.Add(
    new object[ {"2008", 300, 545 });
    dt.Rows.Add(
    new object[ {"2009", 444, 400 });
    chart.Data.ZeroAligned = true;
    chart.DataSource = dt;
