385
Row Layout Question
If I'm using RowLayout in the UltraGrid, can I make the different rows different heights?  I don't mean set Row Sizing to "Free."  I mean, that if a row has certain cells hidden, can I resize that row so that there isn't empty space?
In my example, only the Rectangle needs a second "row" of information.  Is there a way to get the Line and Square rows to be only "one row" tall to fill the void?
When I attempt to resize the Line or Square rows, the grid stops me from going smaller than the height of two "rows."
  • 469350
    Verified Answer
    Not really. The Layout in each row has to be the same. You might be able to resize the cell using a CreationFilter, but this would probably be rather complicated and I would not recommend it. Anyway, this would not change the row height, it would justmake the cell bigger so it fills the available space.
