How to autosize the columns after creating a worksheet?
I took the liberty of suggesting this, I currently use a XamDataGrid and write directly into the Excel sheet without using the Infragistics DataPresenterExcel solution and setting the width based on the string length times a constant doesn't display nicely for me.
http://ideas.infragistics.com/forums/192363-wpf/suggestions/7122068-autosize-excel-columns
Big thanks to miker55! I dropped this method into my solution and BAM! worked like a charm.
Thanks a ton!
Miker55,
Thanks for your contribution. I am using your latest revision and it seems to work fine. I'm using the InfragisticsWPF4.Excel.v10.3 library and it doesn't have a SetWidth method. I'm using this instead and it seems to work OK.
wksheet.Columns[colIndex].Width = colWidths[colIndex] * 256;
instead of
wksheet.Columns[colIndex].SetWidth(colWidths[colIndex] + 2, WorksheetColumnWidthUnit.Character);
Upon testing, the widths were either WAY too big or just a tiny bit too small. So, I changed it to use the SetWidth() method and used the WorksheetColumnWidthUnit.Character since I knew the specific number of characters. I was also able to track down the too big problem to being that spaces take up a LOT smaller space than any other charcter so I cut the number of characters for spaces in half. And finally since Excel changes the width down by fractions of characters most likely for the grid lines and padding, I decided to just add 2 more to the final width to compensate. Here is the revised method with comments:
/// <summary> /// Autosize the columns using their text as a measuring guide /// </summary> /// <param name="book">Excel book</param> /// <param name="sheet">Excel sheet</param> public static void AutoSizeColumns(Workbook book, Worksheet sheet) { Dictionary<int, int> colWidths = new Dictionary<int, int>();
using (Graphics g = Graphics.FromHwnd(IntPtr.Zero)) { // loops through all worksheets in the workbook foreach (var wksheet in book.Worksheets) { // if (sheet == null || (book.Worksheets.Contains(sheet) && wksheet == sheet)) { // couldn't guarantee that the worksheet had columns every time // so had to loop through rows and cells instead to find the correct width foreach (var row in wksheet.Rows) { foreach (var cell in row.Cells) { // get width of cell value string value = cell.Value.ToString();
// width w/o spaces is initially retrieved int width = value.Replace(" ", "").Length;
// reduces width to compensate for small size of spaces width += (value.Length - width) / 2;
// add width to collection for later reference if (!colWidths.ContainsKey(cell.ColumnIndex)) colWidths.Add(cell.ColumnIndex, width); else if (value.ToString().Length > colWidths[cell.ColumnIndex]) colWidths[cell.ColumnIndex] = width; } } } // loops through the new column widths and set each column to the new widths foreach (var colIndex in colWidths.Keys) { wksheet.Columns[colIndex].SetWidth(colWidths[colIndex] + 2, WorksheetColumnWidthUnit.Character); } } } }
Thanks for this recommendation. The problem with this block of code is that we are not using the UltraGridExcelExporter, but using the Infragistics Excel interops to write directly to an excel file. There is no "BeginExport" event to tie this code to.
