120
Select node performance
I have tree with thousands of nodes (up to 2 000). Loading is quite fast thanks to AddRange method in Nodes property. Now I have a task to set many of the nodes (or each of them) to Selected = true. There is very bad performance with that.
Code looks like that:
foreach( UltraTreeNode childNode in Nodes)
 if( someCondition)
  childNode.Selected = true;
Profiler says, that most of the time is spent in node.Selected = true (more specifically SelectedNodesCollection.InternalAdd and finaly ArrayList.Contains - this is the problem). I was trying to find something like SelectedNodes.AddRange method or something like that but with no success. What can I do to speed up nodes selection ? Thanks for any advice.
Daniel
