I'm looking for a way to bold a selected text in my wingrid by clicking a bold button on my ribbon.
For example, I have a wingrid (grid_Questions) setup with a column (IVR_RTF_Text_US) pointing to my formattedTextEditor (txtFormattedForGriduse). It is setup using this line of code: grid_Questions.DisplayLayout.Bands(0).Columns("IVR_RTF_Text_US").EditorControl = txtFormattedForGriduse
I know how to format selected text in the txtFormattedForGriduse control from the ribbon. I assign this value to the click event of the bold button on the ribbon: txtFormattedForGriduse.EditInfo.PerformAction(FormattedLinkEditorAction.ToggleBold). This works for formatting the object outside the grid.
However, I also want to do the same thing when I've selected text within a winGrid column, but I can't figure out how to accomplish this. I know that I can right click my cell in the grid and select bold (and I have this working), but I also want a user to be able to select the text in the cell and click the bold button on the ribbon. Is this possible to do?
Mike, thanks for the help. I was able to take this and make it work for my purposes.
You can do this using the PerformAction method of the editor in the cell. Note that I am referring to the editor here, which is not the same as the editor control. The code would look something like this:
UltraGrid grid = this.ActiveControl as UltraGrid; if (grid != null) { UltraGridCell activeCell = grid.ActiveCell; if (activeCell != null) { FormattedLinkEditor formattedLinkEditor = activeCell.EditorResolved as FormattedLinkEditor; if (formattedLinkEditor != null) { formattedLinkEditor.PerformAction(FormattedLinkEditorAction.ToggleBold, false, false); } } }
