160
Reversing an axis
I actually replied to this post:
http://forums.infragistics.com/forums/t/5073.aspx
 but I think the support team probably won't open that post.
Questions for David:  (Of course, answers from anyone are welcome.)
[Infragistics] David Negley:
"that is correct.  however, in WinForms and ASP.NET you could implement a custom solution for this using a custom layer or the FillSceneGraph event.  it would be tricky, but basically you can redo the labels on one axis, and resize/reposition the data in the chart layer.
another way to approach this would be to modify the data (multiply all the values by -1) and just use IRenderLabel to change the axis labels so it appears values on a reverse scale are being plotted."
Hi David,
 Great idea. I've implemented the second approach successfully.
My first thought was to reverse the x-axis RangeMin and RangeMax in FillSceneGraph event handler like this:
                            IAdvanceAxis xx = (IAdvanceAxis)ultraChart1.CompositeChart.ChartLayers[0].ChartLayer.Grid["X"];
                            double minPos = xx.MapMinimum - 10; //give more space to start/end of axis to avoid Icon trimming
                            double maxPos = xx.MapMaximum + 5;
                            //spatialTrendsChart.XAxis.RangeMin = (double)xx.MapInverse(minPos);
                            //spatialTrendsChart.XAxis.RangeMax = (double)xx.MapInverse(maxPos);
                            spatialTrendsChart.XAxis.RangeMin = (double)xx.MapInverse(maxPos);
                            spatialTrendsChart.XAxis.RangeMax = (double)xx.MapInverse(minPos);
                            spatialTrendsChart.XAxis.RangeType = AxisRangeType.Custom;
This does work for the chart: everything is horizontally mirrored. However, the axis labels are gone (not displayed).
  • What's actually causing this behavior?
  •  And if you don't mind, I'd appreciate if you could elaborate a bit on your first approach as well.
Cheers,
Jason
