907
Anyone have a workign example of a numeric editor working in a tree control?
I can get it to display numbers, but when I try to change a value of 0 to 1, I get the followign error: 'Unable to update the data value: The editor's current value is not valid."  I also can't get the spin button to appear...
Below are the editor declaration and configuration that are used by the cells
// Used as the editor to add to cells that need a checkbox or numeric editor.
// We have to add a static instance to each cell, rather than the column if we
// want to only have the editors in some cells and not all cells in the column
private UltraCheckEditor ultraCheckEditor = new UltraCheckEditor();
private UltraNumericEditor ultraNumericEditor = new UltraNumericEditor();
public FieldListControl() {
InitializeComponent();
// Set some default behaviors for the numeric editor we'll use in our cells.
ultraNumericEditor.NumericType = NumericType.Integer;
ultraNumericEditor.PromptChar = ' ';
ultraNumericEditor.SpinButtonDisplayStyle = ButtonDisplayStyle.OnMouseEnter;
Here is how I try to use the editors
// Setup the override editors
node.Cells["Override Min Length"].AllowEdit = AllowCellEdit.Full;
node.Cells["Override Max Length"].AllowEdit = AllowCellEdit.Full;
node.Cells["Override Min Length"].EditorControl = ultraNumericEditor;
node.Cells["Override Max Length"].EditorControl = ultraNumericEditor;
// Get our numeric control for editing overrides
UltraNumericEditor minLenIntCtrl = node.Cells["Override Min Length"].EditorControl as UltraNumericEditor;
UltraNumericEditor maxLenIntCtrl = node.Cells["Override Max Length"].EditorControl as UltraNumericEditor;
if (minLenIntCtrl != null && maxLenIntCtrl != null) {
// Configure our numeric controls
minLenIntCtrl.MinValue = field.MinLength;
minLenIntCtrl.MaxValue = overrideField.MaxLength;
minLenIntCtrl.Value = overrideField.MinLength;
node.Cells[
"Override Min Length"].Value = overrideField.MinLength;
maxLenIntCtrl.MinValue = overrideField.MinLength;
maxLenIntCtrl.MaxValue = field.MaxLength;
maxLenIntCtrl.Value = overrideField.MaxLength;
node.Cells[
"Override Max Length"].Value = overrideField.MaxLength;
In my test case on a min length override value.   MinValue = 0, MaxValue = 10 wit ha Value of 0
I can type in anything I want, I tried 1,5,9,10 and 23 and all get the same error.
I've been experiment with various properties, including numeric type to no avail.
I also have the CellValueChanged event configured and the cell value never changes, nor does the editor...
Looking for new idea to try here...
