Is there a way to force a PopupMenuTool on a Toolbar to be exactly as high as a ButtonTool (the latter is bigger)? When you have both on a Toolbar and hide the ButtonTool the toolbar shrinks because the PopupMenuTool (dropdown) is smaller and the content then resizes. This is very annoying and occurs in our (tabbed MDI)program since we moved to version 8.2.
We temporarily tried the 8.2 hotfix (looking for a description *what* it should fix wasn't fun) but that didn't help
Any hints how to work around of fix this are very welcome :)
In my application Popupmenu tool have no caption, but button tool have caption.
In ribbon these tools top alignment are showing differently.
See the attachment, a red line denotes the difference in alignment.
The referred dll is Infragistics2.Win.UltraWinToolbars.v8.1
Can we solve this?
Ceaser
The varying heights is still an issue, even with 9.1, as you hot track across toolbar tools. The varying hot track heights is visually annoying. PopupMenu tools and ButtonMenu tools should be the same height.
It could be a bug. You can submit it to the support group if you'd like: http://ko.infragistics.com/gethelp.
As a workaround, you can try to put a LabelTool with no text on the toolbar. If that requires as much height as the ButtonTool, it might prevent the toolbar's height from decreasing when the ButtonTool is removed.
