55
Ultra Chart FillSceneGraph not painting all Primitives
I'm trying to divide a bubble chart into 9 different quadrants drawing lines and labels on the chart using Scene Graph. This requires me to add 10 primitives to scene graph object. After I add the 6th primitive, the chart no longer draws the last 4 objects. I've changed the order of adding the primitives and only the first 6 get drawn, so I know the issue is not with the primitive objects.
I'm using Infragastics Win Forms 16.2. Below is the code in the scene graph
Private Sub UltraChart1_FillSceneGraph(ByVal sender As System.Object, _
ByVal e As Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs) Handles UltraBubbleChart.FillSceneGraph
Try
Dim xAxis As IAdvanceAxis = CType(e.Grid("X"), IAdvanceAxis)
Dim yAxis As IAdvanceAxis = CType(e.Grid("Y"), IAdvanceAxis)
If xAxis Is Nothing Or yAxis Is Nothing Then
Return
End If
Dim gridLine As Line = New Line(New Point(xAxis.Map(0.34), yAxis.Map(0)), New Point(xAxis.Map(0.34), yAxis.Map(1)))
gridLine.PE.Stroke = Color.Black
gridLine.PE.StrokeWidth = 5
e.SceneGraph.Add(gridLine)
gridLine = New Line(New Point(xAxis.Map(0.67), yAxis.Map(0)), New Point(xAxis.Map(0.67), yAxis.Map(1)))
gridLine = New Line(New Point(xAxis.Map(0), yAxis.Map(0.34)), New Point(xAxis.Map(1), yAxis.Map(0.34)))
gridLine = New Line(New Point(xAxis.Map(0), yAxis.Map(0.67)), New Point(xAxis.Map(1), yAxis.Map(0.67)))
Dim labelText As New Text()
labelText.PE.Fill = Color.Black
labelText.labelStyle.Font = New Font("Arial", 20.0, FontStyle.Bold)
labelText.bounds = New Rectangle(CInt(xAxis.Map(0.15)), CInt(yAxis.Map(-0.05)), 100, 25)
labelText.SetTextString("Value")
e.SceneGraph.Add(labelText)
labelText = New Text()
labelText.bounds = New Rectangle(CInt(xAxis.Map(0.45)), CInt(yAxis.Map(-0.05)), 100, 25)
labelText.SetTextString("Neutral")
labelText.bounds = New Rectangle(CInt(xAxis.Map(0.75)), CInt(yAxis.Map(-0.05)), 50, 25)
labelText.SetTextString("Growth")
labelText.bounds = New Rectangle(CInt(xAxis.Map(-0.2)), CInt(yAxis.Map(0.15)), 100, 25)
labelText.SetTextString("Small")
labelText.labelStyle.Orientation = TextOrientation.VerticalLeftFacing
labelText.bounds = New Rectangle(CInt(xAxis.Map(-0.2)), CInt(yAxis.Map(0.45)), 100, 25)
labelText.SetTextString("Mid")
labelText.bounds = New Rectangle(CInt(xAxis.Map(-0.2)), CInt(yAxis.Map(-0.45)), 100, 25)
labelText.SetTextString("Large")
Catch ex As Exception
End Try
End Sub
Below is how I set the data source
With Me.UltraBubbleChart
.DataSource = graphSource
.Axis.X.TickmarkStyle = Infragistics.UltraChart.Shared.Styles.AxisTickStyle.Smart
.Axis.X.Labels.ItemFormat = Infragistics.UltraChart.Shared.Styles.AxisItemLabelFormat.Custom
.Axis.X.Labels.ItemFormatString = "<DATA_VALUE: ##.####>"
.Axis.X.Labels.Layout.Behavior = AxisLabelLayoutBehaviors.Auto
 .Axis.Y.TickmarkStyle = Infragistics.UltraChart.Shared.Styles.AxisTickStyle.Smart
.Axis.Y.Labels.ItemFormat = Infragistics.UltraChart.Shared.Styles.AxisItemLabelFormat.Custom
.Axis.Y.Labels.ItemFormatString = "<DATA_VALUE:##.####>"
 .DataBind()
End With
