255
Double click event for node collapsing .....
Hi ,
I have UltraWinTree with several nodes . On single clicking a node say "first node" , the Subsequent childnodes should open and on double clicking "first node" node again , the nodes should collapes .
So , i used three events and 1 integer to handle this issue . The below code is working fine for the single click to expand the nodes, but when i double click the parentnode to collapse its childnodes continously then for the third or fourth time the nodes collapsing happening for the single click . please help me solve this issue ....
Integer:
int UTAttributesCollapseFlag  = 0 ;
Events :
1) private void UTAttributes_AfterCollapse(object sender, NodeEventArgs e)
         UTAttributesCollapseFlag = 1;
2) private void UTAttributes_MouseDoubleClick(object sender, MouseEventArgs e)
Point currentPoint = new Point(e.X, e.Y);
UltraTreeNode node = UTAttributes.GetNodeFromPoint(currentPoint);
if (node != null)
if (UTAttributesCollapseFlag == 1)
node.CollapseAll();
UTAttributesCollapseFlag = 0;
3)private void UTAttributes_MouseClick(object sender, MouseEventArgs e)
if (node != null)
if (node.Expanded == false)
if (UTAttributesCollapseFlag == 0 )
node.ExpandAll();
