I have a c# winform using an ultrachart 2d bar chart. The tooltips on each bar data point have no delay and I would like to add one. It does not seem possible to do with the base tooltip but maybe I'm missing something. Also I tried to use a custom tooltip but in order to do this I need access to the bar user control list which I can't figure out how to access. Please assist!
Hi Ken,
This feature is not supported in UltraChart. I recommend submitting custom tooltip delay as a product idea for our newer chart control, UltraDataChart. You can suggest new product ideas for future versions on http://ideas.infragistics.com.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case.
Thank you in advance to submitting your product idea.
As this is a duplicate of another thread, I will continue to reply here: https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/118232/tooltip-delay-with-ultrachart
