In the course of adding and removing dock areas I have two left over that I am not using. They have no panes or controls associated with them and I can't see them apart from in the properties grid. How do I remove them?
Thanks Mike - not an issue now as I have removed the control. Feel free to pass the bug on to your developers.
Nick.
I think the best way to remove them would be to remove the definitions of those member variables in the designer generated code and all references to them in the InitializeComponent code (I would make a copy of the file before modifying it). I would also recommend submitting the issue to the support group because it sounds like a bug: http://ko.infragistics.com/gethelp.
