690
UltraCombo preventing application from closing
I've found that Alt + F4 does not close our application when an UltraCombo with multiple selection has the focus. We are using version 16.2.
I have seen a number of older threads on this topic and I've checked that LimitToList is false and AllowNull is true. I also tried adding an event handler for ItemNotInList and it does not fire. The control is bound to a DataTable, except for the checkbox column.
One thing that might be different is that the application is an MDI application. Ctrl + F4 does close the form, and clicking the X button on the MDI parent form also closes the application, so it appears that Alt + F4 is the only thing that is ignored.
Are there any other properties that I should be looking at? Thanks.
  • 34850
    Hello Alec,
    I have been investigating into this behavior you are reporting with "Alt+F4" failing to close the application, and I have reproduced the behavior that you are seeing. It seems that this behavior is directly associated with the multiple selection of the UltraCombo being enabled. I believe what is happening is that for some reason, we are essentially "swallowing" the Alt key-press.
    This is unexpected behavior, and as such I have asked our engineering staff to examine it further. To ensure it receives attention, I have logged this issue in our internal tracking systems with a development ID of 253271 and have created you a private support case, CAS-195842-B2H5S1 which I will link to this issue so you can track its progress. You can access that support case here.
