120
Why is my UltraGridRow ListObject null after loading a serialized DisplayLayout
I am using an Infragistics UltraGrid in my WinForms application. Infragistics v13.1.
I have recently added code to save grid layouts in a binary serialized format and load them back using the CopyFrom method on the DisplayLayout object.
While I load one of these saved layouts, the grid is modified appropriately and data still shows correctly in the grid, but any time I ask for a ListObject on a row, it returns null. The datasource for the grid is a BindingSource whose DataSource is a BindingList (this data is not changed when the layout is loaded).
Save:
Dim MS As New IO.MemoryStream()
ugl.Save(MS, Infragistics.Win.UltraWinGrid.PropertyCategories.All)
Return MS.ToArray()
Load:
Private Function ConvertToUltraGridLayout(data As Byte()) As UltraGridLayout
    Dim ugl As New UltraGridLayout()
    Dim MS As New IO.MemoryStream(data)
    MS.Seek(0, IO.SeekOrigin.Begin)
    ugl.Load(MS, Infragistics.Win.UltraWinGrid.PropertyCategories.All)
    Return ugl
End Function
dgrServices.DisplayLayout.CopyFrom(ConvertToUltraGridLayout(lOption.Layout))
What do I need to do to get the ListObject to be non-null?
Thanks!
