15
ultraDataChart c#
I'm a beginner and I need a little help.
 I read some values from different txt files and I want to plot them at the same chart.
Can you help me with an example?
Thank you
  • 12480
    Hi Tamas,
    I recommend starting out by reading our Getting Started with DataChart topic to familiarize yourself with how our chart works and what its capabilities are. Next, take a look at the topic for each series to see a code example of how to do basic setup and databinding. For example, see the example in our Column Series topic.
    In order to pull the data from multiple sources, I recommend reading the text files in and building a single datasource which you can bind to the UltraDataChart.
