570
Sort Indicator
I have several columns in a grid that are set to the style of check boxes. At first the columns were large because of the header, but now that I have upgraded 8.2 and have been able to rotate the text I am trying to shrink the columns down. The problem is when I rotate the text and apply a sort, I finding the sort indicator takes up a lot more room when the text is rotated vertically compared to the default of horizontal. The extra room appears to be somesort of white space issue, is there a property control how much padding is need when the text is rotated that I need to change?
