1070
In 2017.2 Workbook.Recalculate(true) does not recalculate all formulas
We recently upgraded from 2015.1 to 2017.2. After the upgrade, we're finding that calling Recalculate(true) before saving workbook no longer recalculates all formulas. It looks like this affects formulas that reference cells that also have formulas that reference a different sheet in the workbook. I can't attach the data as it is proprietary.
Is this something that you guys are aware of? It broke some existing functionality that is in heavy use. To be clear, the .xlsx file opens fine in Excel and the formulas recalculate. But a non-Excel application that we use no longer sees the updated formula data in 2017.2
I tried setting IterativeCalculationsEnabled=true on the Workbook, but still no luck. Please advise.
  • 29045
    Hello Kobie,
    Thank you for contacting Infragistics. We have not seen this behavior. Do you have the Workbook's CalculationMode set to Manual with RecalculationBeforeSave set to True?
    I attached a sample below. Please modify it according to your specifications and provide all relevant code in your application to reproduces the behavior.
    SpreadsheetUpdate.zip
