150
InfragisticsWorksheetCell.GetText() throws exception for cell with custom format #/#### "SF"
I wanted to document an exception I am seeing when using the Excel library to read a specific custom cell format.
If an Excel cell has the following:
  • Value                                     .001
  • Custom Format                 #/#### "SF"
  • Excel displays                  1/1000 SF
Then reading the cell with InfragisticsWorksheetCell.GetText() throws the following exception:
System.InvalidOperationException was caught
HResult=-2146233079
Message=The cell's format string is invalid. To be notified of this when the FormatString is set, set Workbook.ValidateFormatStrings to True.
Source=Infragistics4.Documents.Excel.v18.1
StackTrace:
at Infragistics.Documents.Excel.WorksheetCellBlock.GetCellTextInternal(Worksheet worksheet, WorksheetRow row, Int32 rowIndex, GetCellTextParameters paramters, Object value)
at Infragistics.Documents.Excel.WorksheetCellBlock.GetCellTextInternal(WorksheetRow row, Int32 rowIndex, GetCellTextParameters paramters)
at Infragistics.Documents.Excel.WorksheetRow.GetCellTextInternal(WorksheetCellBlock cellBlock, GetCellTextParameters parameters)
at Infragistics.Documents.Excel.WorksheetCell.GetText(TextFormatMode textFormatMode)
The following file is a minimal spreadsheet that reproduces the issue with the custom format applied to cell A1:
Thanks for consideration of this issue, and your continued improvements and updates to the Winforms Excel library!
Cheers,
Ben
