340
Creating FlatDataSource from DataTable dynamically and use it in PivotGrid
I am trying to use UltraPivotGrid dynamically from DataTables. I need to create FlatDataSources from these DataTables and use them in PivotGrid. The FlatDataSource is created with data after converting DataTable to list. But when I set the FlatDataSource to PivotGrid, it does not work. Here is the code:
using System;
using System.Collections.Generic;
using System.Data;
using System.Windows.Forms;
using Company.ClientLibraries;
using Infragistics.Olap.FlatData;
using System.Reflection;
using Infragistics.Olap;
using System.Collections;
DynamicTypeBuilder typeBuilder = new DynamicTypeBuilder
DynamicAssemblyName = "MyAssembly",
DynamicTypeName = "Pane"
Type dynamicType = null;
private IList GetListFromTable(DataTable table)
IList<DynamicTypePropertyInfo> properties = new List<DynamicTypePropertyInfo>();
foreach (DataColumn column in table.Columns)
DynamicTypePropertyInfo propertyInfo = new DynamicTypePropertyInfo
PropertyName = column.ColumnName,
PropertyType = column.DataType
properties.Add(propertyInfo);
dynamicType = typeBuilder.GenerateType(properties);
Type listType = typeof(List<>);
Type genericListType = listType.MakeGenericType(dynamicType);
IList list = (IList)Activator.CreateInstance(genericListType);
foreach (DataRow dataRow in table.Rows)
object myDynamicInstance = Activator.CreateInstance(dynamicType);
PropertyInfo propertyVal = dynamicType.GetProperty(column.ColumnName);
if (dataRow[column] != DBNull.Value)
propertyVal.SetValue(myDynamicInstance, dataRow[column], null);
list.Add(myDynamicInstance);
return list;
private void LoadPivot()
try
IList list = null;
list = GetListFromTable(this.dataTable);
if (list != null)
FlatDataSourceInitialSettings settings = new FlatDataSourceInitialSettings();
settings.Rows = "CustomerName";
settings.Columns = "ItemName";
settings.Measures = "Total";
this.ultraPivotGrid1.RowHeaderLayout = Infragistics.Win.UltraWinPivotGrid.RowHeaderLayout.Compact;
FlatDataSource ds = new FlatDataSource(
list, dynamicType, settings);
ds.DisplayName = "Orders by ItemName";
this.ultraPivotGrid1.SetDataSource(ds);
catch (Exception ex)
#if DEBUG
ErrorHelper.ProcessError(ex);
#endif
