80
Too much Space on selves sizing Popup
since I add the title bar style with the RibbonMenue from the UltraToolbarsManger I got too much Space
on the button and the right hand side.
I was tried to set the dock property from Fill, Parent ... a lot of combinations.
At last I find out that the spaces disappear, if I set FormBorderStyle from the PopUp window to none.
But then the Close button from the Ribbon menu doesn't work...
The tabs were an UserControl witch I add on creation with the setting Dock.Fill.
On Picture two I set the DockWithinContainer to the panel witch will contains the added user control.
