Hi All.
I am storing the recurrence as a byte array into the database. There is another program that keeps the track of the reminders. How can the other program read the database and interpret the byte array to read the occurrences and take action?
Please send the function that can read the byte array and give readable data to the program.
Thanks.
Hello Darr,
In order to read a byte array into a usable recurrence in the WinSchedule family of controls, I would recommend using the static AppointmentRecurrence.FromBytes(byte[] bytes) method. If a valid byte[] is provided, an AppointmentRecurrence will be returned for use with your Appointment’s Recurrence property. So, you could use the following code for this:
AppointmentRecurrence recurrence = AppointmentRecurrence.FromBytes(myByteArray);
The schedule types Task, Note, Owner, Project, and Appointment also have this same static method.
I am facing a similar issue. The other program is not using winschedule controls. Still needs to use the appointment data.
Is there any way to interpret / read the recurrence / allproperties data stored in the database to plain text.
Many thanks.
