Hi there
I have a C# .NET 4.5.2 WinForms app using the Infragistics UltraWinGrid v16.1.20161.2033 control
It is using a grid with the ViewStyleBand.OutlookGroupBy in play and I have the grouping configured just the way I want it with 2 columns in the GroupByBox
The last piece of the puzzle is to prevent the user from adding/moving/removing columns from/within the GroupByBox.
I would like if possible to keep the GroupByBox visible as it allows the user to apply sorting to the 2 columns as desired.
What is the best means of preventing the end user from from adding/moving/removing columns from/within the GroupByBox but still allowing them to sort as they desire?
Thanks in advance
Geoff
Thanks Mihoko worked a treat.
Regards
Hello Geoff,
I suggest you set UltraGrid.DisplayLayout.Override.AllowGroupBy property to false. With this setting, you should be able to prevent users from grouping/ungrouping while keeping the groupby area still visible for sorting.
I have attached the sample to demonstrate this behavior.
Please let me know if I may be of further assistance.
8156.WindowsFormsApplication1.zip
