245
How to add new Nodes to UltreTree through a BindingList as a DataSource
For efficiency reasons I need to load some sub-nodes at BeforeExpand event but simply adding this new sub-data to the BindingList seems to don't work visually on the UltraTree(18.x), because the BindingList keeps the added data to the appropriate node but UltraTree seems can't add the new Nodes in question.
After DoubleClick for expanding the Node, data is added, and I do even an ExpandAll and Refresh(on UltraTree) at the end but nothing seems to work to render the added data to the DataSource and I'm lost.
The ViewStyle of the UltraTree is setup on Standard, is there any chance that a custom setting on the UltraTree is preventing the update of the new added sub-nodes?
Here's the structure of the data itself, if it can help:
Public Class UserTable
     Public Property Database As String
     Public Property Schemas As List(Of Schema) = New List(Of Schema)
End Class
Public Class Schema
     Public Property SchemaName As String
     Public Property Tables As List(Of Table) = New List(Of Table)
End Class
Public Class Table
     Public Property ShortName As String
     Public Property Name As String
     Public Property Enabled As Boolean = False
 Public Property Columns As List(Of Column) = New List(Of Column)
End Class
Public Class Column
     Public Property Description As String
End Class
And the BindingList is like:
Private Property TablesTree as New BindingList(Of UserTable)
Assigned to the DataSource like:
TablesUltraTree.DataSource = TablesTree
And the nodes that I'm adding are for "Columns" with a function GetColumns() that returns a List(Of Column)
Ps: If I load all the nodes(included the ones that I need to add later) at "Load" event of the form, everything shows as expected
