105
Can't add row to UltraGrid
I have an UltraGrid (v7.3) that I am trying to allow the adding of rows to.
This UltraGrid has a UltraDataSource as its datasource, where the columns are defined.
In the page load event I have the following code
UltraGrid1.DataSource = listOfEvents
UltraGrid1.DataBind();
The listOfEvents is a List<> (code is written in c# 2005)
I have set the UltraDataSource to AllowAdd, however everytime I try to add a new row when the application is running I get the following error in a popup box...
"Unable to add a row:
Unable to add a new row. Underlying DataSource does not support adding new rows."
Is it possible to add new rows in this particular setup? or do I need to have a different  underlying datasource?
Any help of this would be very much appreciated
Thanks in advance
