90
how to remove expansion column in ultragrid
using this "ultraGrid.DisplayLayout.Override.ExpansionIndicator = Infragistics.Win.UltraWinGrid.ShowExpansionIndicator.CheckOnDisplay" able to remove expansion indicator but that space is there so how can remove that please help me out .......... thanks in advance
  • 469350
    If you just want to display a single band of flat data and you will never have any child rows, then another option would be to set:
    grid.DislpayLayout.ViewStyle = ViewStyle.SingleBand;
  • 34830
    Hello Gurumurthy,
    In order to remove the entire expansion indicator column in the UltraGrid, I would recommend setting the Indentation property on the underlying band to zero. You can do this using the following code, where “grid” is the UltraGrid:
    grid.DisplayLayout.Bands[0].Indentation = 0;
