Hello
I have used an UltraTextEditor and UltraSpellChecker, which is assigned as a spellchecker to the UltraTextEditor.
on a button click following code is called.
UltraSpellChecker1.ShowSpellCheck(UltraTextEditor1)
In the dialog, if I change a spelling, it gets changed in the UltraTextEditor, But UNDO does not change it back in the Editor. Though I can see the change undone inside the dialog box text.
How to fix this?
Plus, now the text inside the editor and Spell Check dialog is different, subsequent clicking on Change and undo corrupts the whole text.
Please give me a solution
Thank you.
I am using version 11.1. Is there any work around or old posting that can help me?
I am bound to use the 11.1, so can't update the version.
Hello Tara,
I determined that an issue with the Undo function not updating the editor was fixed back in 2017. Which version are you using? You may test our latest volume release to see if it's been resolved.
