Hi
I have some question about UltraLiveTileView.How can I setting Scale of UltraLiveTileView?I know there is Scale methode. but it is not working.And ResolutionScale can Change Only 4 Types.(80%, 100%, 140%, 180%)
I want LiveTiles Medium size more less than 120 * 120.ResolutionScale only reduces it to 80%.
So how can i do this?
pls I'm waiting your answer.
thanks.
Hello Bok Sil,
The tile sizes of UltraLiveTileView are determined based on the tiles in the Windows 8 start screen.You can change the size using ResolutionScale property to some fixed scales as you have already tried.However, the control does not support the functionality to set the tile size freely like in pixels.
You can suggest this as a new product ideas for future versions (or vote for existing ones) at <https://ko.infragistics.com/community/ideas>.Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.Thank you in advance to submitting your product idea.
