20
Saving a Graphics Pie Chart to PDF
I am trying to draw a Pie Chart using the Graphics.FillPie() Method. On the screen, it works perfectly; however, when trying to save it to PDF using an Infragistics.Documents.Reports.Report.Report and publishing it as a PDF, it is not being drawn correctly. I have attached an example test application showing the problem. It appears that the sweepAngle parameter in the FillPie Method is being extended far past what is being specified.
Could you please let me know if this is a bug or something that I am doing?
I am also using Infragistics4.Documents.Reports v17.2
SaveToPDF.zip
  • 18204
    I have created a support case for you with an ID of CAS-200277-C4Q6V3.  The matter has been determined to be a development issue and has been logged in our tracking system with ID: 260953.
    I will leave this case open and update you with any new information.  You can view the status of the development issue connected to this case by going to the “Account” tab on our website, selecting "My Support Activity" and then this support case will be listed there.  Then, you may select the "Development Issues" tab to view details of this development issue.
