I want to know whether the infragistics grid control will support the concept illustrated below, where the charges column is further divided into three related columns: Open, Total and most serious?
Um, there's no illustration here that I can see. :)
The grid can't divide a column, but it sounds like you could acheive what you want using 3 columns and a Group to provide a header for all three columns. You might also be able to acheive what you want using a RowLayout with a dummy column which just provides a header.
