When I drag a column header up to the group area for the UntraGrid the rest of the headers hide. I need the headers to not hide. Is there a setting I am missing? None of the other grids do this just one of them.
Hello Randy,
Thank you for posting.
If your none of the other grid is showing this behavior then my first guess would be that you might have set ‘HeaderPlacement’ to ‘FixedOnTop’ or band HeaderVisible to false in this grid.
If not then you would have to compare what else did you set in this grid causing different behavior then your other grids.
If you are still not able to find the cause of the issue, the best way for us to assist you is if you provide a small isolated sample that we can run and use for debugging locally.
Looking forward to hear you back.
Sincerely,Divya JainAssociate Software Developer
