1612
UltraGrid - prevent ActiveRowAppearance background to change cell background
Is there an option to set ActiveRowAppearance.BackColor that way it will not overwrite cells bacground ?
Im my project Im showing discrepancies in cells by cell's BackColor = Red
If I have ActiveRowAppearance.BackColor = Blue I cant see any cells markings
I tried to use BackColor alpha level etc but with no much luck
Unfortunately I need clear ActiveRow clear marking - border / font color change is not enough - BackColor is most welcome by users
  • 25665
    Hello Maciej,
    You will want to set the ActiveAppearance on the cell, in addition to the Appearance:
    private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
    var layout = e.Layout;
    var band = layout.Bands[0];
    var ov = layout.Override;
    ov.ActiveRowAppearance.BackColor = Color.Red;
    private void ultraGrid1_InitializeRow(object sender, InitializeRowEventArgs e)
    var row = e.Row;
    row.Cells[1].Appearance.BackColor = Color.Yellow;
    row.Cells[1].Appearance.ForeColor = Color.Black;
    // If you don't do this, the ActiveRowAppearance will override the yellow for
    // the cell in the active row.
    row.Cells[1].ActiveAppearance.BackColor = Color.Yellow;
    row.Cells[1].ActiveAppearance.ForeColor = Color.Black;
