160
Versioning issue
We've used Infragistics for many years and the main difficulty we have is with versioning.  All of our developers use a specific minor version (e.g. 18.2).  But if one developer needs to re-install 18.2, they might get a revision that is different than what they had previously.  That leads to errors such as:
System.IO.FileLoadException: Could not load file or assembly 'Infragistics4.Win.UltraWinGrid.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)File name: 'Infragistics4.Win.UltraWinGrid.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'
When we've encountered this issue in the past, we've required ALL developers to re-install 18.2 to get the same revision that the one developer got.  Is there a way to obtain an exact version rather than allowing the installer to always get the latest and greatest?
We've considered using version-free assemblies but having to add binding redirects to all of our app.config files is even less desirable than having all developers re-install.
Are there any other options that we haven't considered?  Any advice would be greatly appreciated.
