This is a 2 part question:
1) It seems that whenever I click on a PopupControlContainerTool in the application menu it closes the application menu. This differs from old file menu's. Ie, a user would expect File->New + click to just open the new menu, even though its already open on mouseover.
2) My goal is to have a multi-select PopupGalleryTool, PopupMenuTool, or PopupControlContainerTool. I could use a check list box in the PopupControlContainerTool but the popup doesnt automatically resize to the ToolAreaRight. If I use a gallery or menu tool, clicking closing the window and there can only be a single selected item at a time. Please help.
Mike
mikeahoyle said:1) It seems that whenever I click on a PopupControlContainerTool in the application menu it closes the application menu. This differs from old file menu's. Ie, a user would expect File->New + click to just open the new menu, even though its already open on mouseover.
This seems like it might be a bug. I would recommend submitting it to the support group: http://ko.infragistics.com/gethelp.
mikeahoyle said:2) My goal is to have a multi-select PopupGalleryTool, PopupMenuTool, or PopupControlContainerTool. I could use a check list box in the PopupControlContainerTool but the popup doesnt automatically resize to the ToolAreaRight. If I use a gallery or menu tool, clicking closing the window and there can only be a single selected item at a time. Please help.
You could submit a feature request to have a property on the PopupControlContainerTool allowing it to expand when it is opened over the ToolAreaRight: http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
