Infragistics.Documents.Excel is somehow not recognizing an xlsx file that has columns referencing an external xlsm file in a formula. Before I dig in further to see what is wrong, I just want to confirm if this scenario is supported.
Hello Joseph,
I have been able to download your workbooks and when loading the .xlsx, I am able to reproduce the FormulaParseException that you are referring to. This behavior is unexpected, and as such, I have asked our engineering teams to examine it further.
To ensure that this receives attention, I have logged it in our internal tracking systems with a development ID of 266244. I have also created a private support case for you that this issue will be linked to. This support case has an ID of CAS-203924-D6F9R5 and you can access it at https://ko.infragistics.com/my-account/support-activity.
Sorry, our mail server is preventing me from sending the files. Can you download it from this location?
transfer.dmsi.com/.../cedar_board_price_import.zip
File is submitted to the support email.
You can add files to the thread by using the Insert drop-down and selecting the “Insert Image/Video/File” option. You will be prompted with a dialog box asking for a source (From) and a File.
Note, you can only attach files that are 1MB or less to the Infragistics forums. If your files are larger than this, please send it in an e-mail to support@infragistics.com.
I was able to load the file you attached but not my original file. This is the method I'm using to load the file;
Infragistics.Documents.Excel.Workbook.Load(<filename>, false)
How do you add/attach a file to the thread?
