I have am UltraGrid that is bound to a Windows.Forms.BindingSource. When I click on a column that contains integers the grid enters edit mode and the cell is highlighted but I am unable to change the value.
Column.AutoEditMode = True
Column.CellClickAction = Edit
Steve
Hello Steve Hager,
Thank you for making a post to our forum.
Since I don't know what kind of data source you use, I anyway tried to reproduce your issue, using a BindingSource bound to a List<T> collection, but your issue wasn't reproduced.
I attached a sample application I'd given a try.
Could you also verify it to see whether or not the issue is reproduced in this sample?
Here are the steps I followed:1. Run the sample application.2. Click one of the cells of the "Age" column. -> The cell enters an edit mode.3. Change the value to any numeric.4. Hit [Tab] key to exit the edit mode.-> The cell's value expectedly changes to that which was entered in the step #4.
If you can see what is necessary to reproduce your issue in the sample, could you point it out?
8640.F120608-SampleApp1.zip
