90
Can't activate a tool that does not belong to this UltraToolbarsManager.
hi i am using ultratoolbarsmanager while i try to remove tab in ribbon its throwing one error as "Can't activate a tool that does not belong to this UltraToolbarsManager." i tried a lot please give me solution for this error thanks in advance
my code to remove that tab is  -  utmMenu.Ribbon.Tabs.RemoveAt(10);
  • 1560
    Hello Rajendran,
    I have created a small sample trying to reproduce the described behavior. I am using Infragistics Windows Forms 2019 Vol. 1. On my side everything works and expected and I am able to remove the ribbon's tab without any exceptions.
    Attached you will find my sample for your reference. Please test it on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me along with steps to reproduce. Alternatively, if the behavior cannot be replicated please feel free to provide your own sample. Remove any external dependencies and code that is not directly related to the issue, zip your application and attach in in this case.
    Having a working sample on my side, which I can debug, is going to be very helpful in finding the root cause of this behavior.
    Thank you for your cooperation.
    Sincerely,
    Teodosia Hristodorova
    Associate Software Developer
