Dear Infragistics forum community, dear Infragistics,
I would like to know if there are any methods of manipulating RTF objects outside a text box control in Infragistics. For example: taking two formatted mail strings and merging them or converting strings from HTML to RTF and vice versa.
It's important that the method doesn't have to use a control, so I can merge/convert formatted strings which I have already generated elsewhere.
Right now I am using other solutions (TX Text Control) which unfortunately have bugs messing up my texts, so I am looking for alternatives. And since I am already using Infragistics for other reasons and there are (kind of?) already some ways to handle RTF/HTML-strings, I reckoned I'll just ask, so I could maybe switch to this solution.
Anyway, if anybody knows anything, even if Infragistics can't help, let me know
Greetings,
Andreas
Hello Andreas,
Thank you for your post . Unfortunately, we do not have any method to manipulate the RFT object . The only close thing is the document in WPF. I don't think it does what you are looking for, though It just creates documents and exports them to RTF and some other formats.
Maybe you can have a look at these Doc to see if that help .
Let me know if you have any question.
Regards,Divya Jain
To add: Is it possible without using a form, e.g. as a system task?
