Is it possible to set the text of the label on the CategoryToolTipLayer?
As an example, I ran the sample project that was provided in the following thread:https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/118655/change-tooltip-arrow-color-in-an-ultradatachart
Using the above program as an example, how would I relabel the 'Value1", "Value2", and "Value3" labels?
I am glad that you have found my suggestion helpful.
Thank you, that solves it for me!
The default tooltip control is designed to be used pretty much as it is. The underlying collection of controls is dynamically created, and most of its properties are read-only.
The best solution in case you would like to modify the look of the CategoryToolTip layer is to use the Series_TooltipContentUpdating event, and return a new UserControl, which you can design as per your liking.
I have modified the sample and attached it for further reference.
Should you have any further questions, please let me know.
Sincerely,Tihomir TonevAssociate Software DeveloperInfragistics
5875.UltraDataChartCategoryTooltip.zip
