215
DataTable control Binding issue
Hi
I have problem with UltraTextEditor (and other Infra UI components building)
1. Component bound to same DataTable column (eg Name on below example) do not update
    Expected behavior - leaving tbName and focusing (eg tbCity) should result displaying same value in tbName2
2. Change made in components are not reflected in DataTable bound to eg dataGridView
    Expected behavior - leaving (moving focus) from currently edited control should update dataTable / grid
Cant believe this is Infra bug, I must be doing something wrong - appreciate your help here !
Below is sample app code and screen how it works
           DataTable dt = new DataTable();
           dt.Columns.Add("Name");
            dt.Columns.Add("City");
            tbName.DataBindings.Add ( "Value", dt, "Name",true, DataSourceUpdateMode.OnPropertyChanged);
            tbName2.DataBindings.Add( "Value", dt, "Name",true, DataSourceUpdateMode.OnPropertyChanged);
            tbCity.DataBindings.Add( "Value", dt, "City",true, DataSourceUpdateMode.OnPropertyChanged);
            // New row
            dt.Rows.Add ( dt.NewRow() );
            dataGridView1.DataSource = dt;
