Hi guys, i try with other topic to show the scroll bars in a ultratilepanel, (and tks again), but i dont like this solution.
when i add tils the bar appear and hide again, now i want try to hide completly th scrollbars.
i scroll the tiles with the central button without scrollbars, its possibile?
i dont wanna that the scrll bar use the space into tilepanel.
tks for help.
Hello Luca,
I am not really sure how you are getting a third tile on the same row if your maximum number of columns is set to two. I have tried to reproduce that but i could not do it.
What would happen though, is that your tiles will be bigger than 100,100.
When you set the maximum number of columns, the tiles will stretch to take all the space. So if you have 2 tiles in a container of 246, the tiles will be probably around 110 each.
Maybe the only way the behavior your describe can happen is if the maximum number of columns is not set from the beginning, and you set it after you add tiles?
Sincerely,Tihomir TonevAssociate Software DeveloperInfragistics
Hi, tks for reply.
i trace the error step by step.
The flashing is not for vertical scrollbar, but from the third tile that try to put horizontal and after goint to a new row.
i have max columns = 2, and the third tile try to site in the row for after shifting to a new row.
Also now my prob is changing to not see these "flash".
Can u hel pme?
tks a lot.
This method skips the drawing of the scrollbar, so i can't really see how it is flashing if it was never drawn from the beginning. My best guess would be that you are seeing another tile?
I have attached a sample adding 9 tiles per button click, but i see no scrollbar flashing.
Can you check the sample(its 17.2), and let me know if it behaves different on your end?
8255.UltraTilePanelNoScrollbar.zip
well i try but not work completly. Now i dont see the vertical scroll bar, but when i add tiles and for the tiles number need vertical scrollbar, its appeare and disappeare. Its a bit "annoying" see the vertical scroll bar flashing everytime the tiles number is more then i can see in the tilepanel.
Other prob about this solution is the tiles resizing, everytime the vertical scrool bar appeare/disappeare
My tilepanel size is 246x389, and every tile size i want to be 100x100. (about 2 columns + borders).
Every time i add the 9th tile (4th row), the vertical scrool bar flash and resizing all tiles. And when i go back under 9 again, all tiles resizing.
i think that can be 2 solutions:
1) the vertical scrool bar always exist but in hide mode
2) the vertical scroll bar always dont exist
its possibile one o these solutions?
Hi tks for reply.
itry with your code, cause, the example use 19.2 version and i have until 17.2 i cannot run it.
