When analyzing a solution it ends with the following error (in the log file)
Could not find directory C:\Program Files (x86)\Infragistics\2014.2\Ignite UI\MVC\MVC5\Bin\ to search for Infragistics assemblies.
The C:\Program Files (x86)\Infragistics\2014.2\Ignite UI\MVC\MVC5 folder is missing on my machine. I only have the Common, MVC2, MVC3, MVC4 folders in that location.
There are no references to Ignite UI in the project. These are the only reference to Infragistics:
<Reference Include="Infragistics4.Shared.v18.2, Version=18.2.20182.130, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=MSIL"> <SpecificVersion>False</SpecificVersion> </Reference> <Reference Include="Infragistics4.Win.UltraWinStatusBar.v18.2, Version=18.2.20182.130, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=MSIL"> <SpecificVersion>False</SpecificVersion> </Reference> <Reference Include="Infragistics4.Win.v18.2, Version=18.2.20182.130, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=MSIL"> <SpecificVersion>False</SpecificVersion> </Reference>
FULL LOG
10:47:11: Running User Interface Version 20.1.20201.110:47:11: Gathering volume and assembly information.10:47:11: Could not find directory C:\Program Files (x86)\Infragistics\2014.2\Ignite UI\MVC\MVC5\Bin\ to search for Infragistics assemblies.11:00:36: ProjectFile element: ActivityLog.csproj is being treated as a proj file.11:00:36: Analyzing ActivityLog.csproj...11:00:36: The project has references that need to be updated.11:00:36: Could not load the project. Please see the Log file for more details.11:00:36: Object reference not set to an instance of an object.11:00:36: at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.CheckProjectForAdditionalFiles(Boolean isSLProject, XmlNode node) at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Analyze()
Hello Sam,
Looks like you created another thread to discuss the same issue, Vasil is from Engineering service team he can provide more detail information about the issue explained in the log file.
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/121595/version-utility-not-upgrading-projects
Maybe you can continue discussing the issue with the other thread and provide the information Vasil asked for.
Thank you.-Divya Jain
I created a test project and the upgrade was done successfully. Like I said, some solutions are done without problems and others have errors that are not descriptive and don't tell me what the problem is.
Here is the log of the successful one. It still mentions the MVC5 folder, but it seems to always do that, even when converting from 2014 to 2018 a while ago. Is there another log that actually describes what the problem is in more detail?
09:43:05: Running User Interface Version 20.1.20201.109:43:05: Gathering volume and assembly information.09:43:05: Could not find directory C:\Program Files (x86)\Infragistics\2014.2\Ignite UI\MVC\MVC5\Bin\ to search for Infragistics assemblies.09:43:17: ProjectFile element: WindowsFormsApp1\WindowsFormsApp1.csproj is being treated as a proj file.09:43:17: Analyzing WindowsFormsApp1.csproj...09:43:17: The project has references that need to be updated.09:43:30: Upgrading Solution WindowsFormsApp1.sln09:43:30: Updating WindowsFormsApp1.csproj...09:43:30: Updating Infragistics4.Win.Misc.v18.2 Version=18.2.20182.130 to new reference Infragistics4.Win.Misc.v20.1. Version 20.1.20201.1209:43:30: Updating Infragistics4.Win.v18.2 Version=18.2.20182.130 to new reference Infragistics4.Win.v20.1. Version 20.1.20201.1209:43:30: Done Updating WindowsFormsApp1.csproj.
If the log says "Could not load the project. Please see the Log file for more details." which log is it asking me to look at? Is there another log that I don't know of? The only error in the current log is what I posted above.
I did notice on some other solutions that it successfully set the references on some of the projects. I don't know why it's successful with some projects and not others. I tried doing a single project and go the following results.
04:59:57: Running User Interface Version 20.1.20201.104:59:57: Gathering volume and assembly information.04:59:57: Could not find directory C:\Program Files (x86)\Infragistics\2014.2\Ignite UI\MVC\MVC5\Bin\ to search for Infragistics assemblies.05:21:00: Analyzing OpsManager.csproj...05:21:00: The project has references that need to be updated.05:21:01: Could not load the project. Please see the Log file for more details.05:21:01: Object reference not set to an instance of an object.05:21:01: at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.CheckProjectForAdditionalFiles(Boolean isSLProject, XmlNode node) at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Analyze()
Why is it looking for Ignite UI in the 2014.2 folder when it's 2020.1
Hello ,
The version utility showing at the bottom is correct.
when I am upgrading the project I have these options in the dialog,
so maybe do not change anything from 'upgrade option' dialog (utility will take it automatically) and hit the button 'upgrade to latest'.
i also noticed that you have so many .csproj file listed, especially notice the 'WebBrowser' project, not sure if this has and web reference , causing the issue, so is it possible for you if you upgrade one project at a time?
Did you try upgrading any test project?
-Divya Jain
