Hello all
I need to fill the coloumn(2) from combobox in grid column(1) when the dropdown closed
how to do that
Thanks Before
Hengky
Have you tried the approach in the KB article?
If you follow the steps in the article and it does not work in the way you expect, could you possibly send a small sample so that I can look into it?
Hai Mihoko
Thanks for reply the solution that you gived to me doesn't work
it's still can not fill next column on grid
Are you trying to dynamically change the items of a combobox in one cell based on the selection of a combobox in another cell on the same row?If that is the case, the KB article below explains how to do it.
HOWTO:How can I change the drop down list on a cell by cell basis in UltraWinGridhttp://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=4878
UltraGrid demonstrated in the above page has two columns, 'Region' and 'State'. Based on the selection on the 'Region' column, you will see the different items in the 'State' column.What you will need to do to achieve this functionality is to assign a datasource of all the possible items to the 'State' column combobox. You will then use UltraGrid's BeforeEnterEditMode event to populate the datasource looking at the value of the 'Region' cell and assign it to the combobox of the particular cell.Please let me know if I may be of further assistance.
