1467
TextVAlign
In the InitializeLayout event of a grid, I set the e.Layout.Bands[bandName].Columns[columnName].Width of each column, and I set
            e.Layout.Override.RowSizing = RowSizing.AutoFree;
            e.Layout.Override.CellMultiLine = DefaultableBoolean.True;
The text automatically wraps if it is not wide enough to fit in a column, and the row height adjusts automatically. However the text in all cells is aligned to the top of the cell. I think the grid would look a lot better if all text were centered vertically instead.
I have tried setting
            e.Layout.Override.CellAppearance.TextVAlign = VAlign.Middle;
and several variants of this, but I have been unable to find a way to make the text in all cells center vertically, although the text in some of them, for example in the Date columns, does do so. There must be a way, but what is it?
