I have one application using UltraGridExcelExporter in Infragistics2.Excel.v10.3 to export excel file. It gives below error.
The application works fine util I upgrade Office 2013 to Office 365.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
at System.ThrowHelper.ThrowKeyNotFoundException()
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at Infragistics.Excel.Serialization.BIFF8.BIFF8WorkbookSerializationManager.WriteWorksheetRowBlocks(Worksheet worksheet, List`1& dbcellRecordPositions)
at Infragistics.Excel.Serialization.BIFF8.BIFF8WorkbookSerializationManager.WriteWorksheet(Worksheet worksheet, Boolean hasShapes)
at Infragistics.Excel.Serialization.WorkbookSerializationManager.WriteWorksheetRecords(Worksheet worksheet, Boolean hasShapes)
at Infragistics.Excel.Serialization.BIFF8.BIFF8WorkbookSerializationManager.SaveWorkbookContents(Boolean workbookHasShapes)
at Infragistics.Excel.Serialization.WorkbookSerializationManager.Save()
at Infragistics.Excel.Workbook.SaveBIFF8File(Stream stream)
at Infragistics.Excel.Workbook.Save(String fileName, IPackageFactory packageFactory)
at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, String fileName)
at RexallHPGClient.InvoiceForm.ExportToExcel(ExportType type)
at RexallHPGClient.InvoiceForm.ultraToolbarsManager1_ToolClick(Object sender, ToolClickEventArgs e)
at Infragistics.Win.UltraWinToolbars.ToolClickEventHandler.Invoke(Object sender, ToolClickEventArgs e)
at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnToolClick(ToolClickEventArgs e)
at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FireEvent(ToolbarEventIds id, EventArgs e)
at Infragistics.Win.UltraWinToolbars.PopupMenuItemUIElement.DoClickProcessing(MouseEventArgs e)
at Infragistics.Win.UltraWinToolbars.PopupMenuItemUIElement.OnMouseUp(MouseEventArgs e)
at Infragistics.Win.TextUIElementBase.OnMouseUp(MouseEventArgs e)
at Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
at Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
at Infragistics.Win.UltraWinToolbars.PopupControlBase.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
This exception is thrown when you try to index to something that isn't there. I was able to find out several issues similar to this that we've already fixed for versions 12.2 and later. The stack trace is similar but not an exact match. In would be helpful if you could provide more details about your scenario and share a sample that demonstrates the exception I could examine the matter in detail.
Please keep in mind that according to our support policy Infragistics products have one year of product service releases and three years of developer support. This means that version 10 is considered retired and it is no longer eligible for Developer Support Services. More about the Infragistics product lifecycle can be found here.
Thank you for your cooperation.
Sincerely,Teodosia HristodorovaAssociate Software Developer
Any advice or idea of the possible cause would be greatly appreciated!!
