4165
Unable to Escape from NumericEditor in a toolbar
We are having an issue with a numeric editor in a toolbar. If a user remove the value and tries to escape the control will not release. They can't even click out of it they have to put in a value. When they hit escape it does not revert to the original value (maybe this has to be coded in key down event?)
Also when they click in the control the number pushes to the right (see screenshot)
This is the code where we create and set the control
            uneTB_RCM = new Infragistics.Win.UltraWinEditors.UltraNumericEditor
                Name = "uneTB_RCM",
                FormatString = "##.#0",
                PromptChar = ' ',
                NumericType = Infragistics.Win.UltraWinEditors.NumericType.Double,
                UseFlatMode = DefaultableBoolean.True,
                Width = 65,
              //  MaskInput = "{double:10.2}",
                AutoSize = true,
                MaxValue = 10000000000
            this.Controls.Add(uneTB_RCM);
            uneTB_RCM.Visible = false;
            var pcRCM = utbTotals.Tools["ccRCM"] as ControlContainerTool;
            pcRCM.Control = uneTB_RCM;
            uneTB_RCM.AfterExitEditMode += uneTB_RCM_AfterExitEditMode;
            uneTB_RCM.KeyDown += uneTB_KeyDown;
Thanks for the help.
M.
  • 34690
    Hello Michael,
    I have been investigating into the behavior you are seeing, and in order to prevent this, you will need to set the Nullable property on your UltraNumericEditor to true. By default, this is false, and the editor will not let you leave if there is no value, but this allows you to leave the editor if there is no value.
